Brief Description: Setting the edge bend on the Canopy Frame Stiffene
Started work on the canopy frame's forward stiffiner assemblies. First, after edge-treating the metal and bending stiffiner flanges into the lightening holes, I bent the fore/aft flanges to fit the canopy frame skins and frame. That done, I positioned them on the frame and match-drilled using the stiffener pieces as the guides, and cleco'd into place.
Using edge bender to bend the stiffener flanges
Edges (over)bent
Edges (un)bent, then match-drilled/cleco'd to the frame
