Sid & Houston Mayeux Project
Date: 12-17-2011
Number of Hours: 3.00
Manual Reference: Roll Bar
Brief Description: Finished/primed, assembled/rivited the roll bar
After deburring, countersinking specific holes that will require flush rivets, and priming, I riveted the roll bar. This took a surprising array of riveting techniques: - For flush rivets, I riveted the inner/outer straps to the forward channel with the pneumatic squeezer. - For flush rivets through the forward channel's center attach plate, I back-riveted into my1/2inch-thick steel plate. - For AN470 standard rivets through the rear channel's center attach plate, I again used the pnematic squeezer. - However, for AN 470 standard rivets through the reach channel's attach plate AND the rear fuselage mount brace's mounting angle, I used the hand-bucking/rivet gun method. - Finally, I filled the rear channel and inner/outer strap holes with CS4-4 pop rivets.
Almost 10 hours just to build the roll bar. At first it seemed to me like an aweful lot of work. But as I thought about the importance of this component's sturdiness and reliability for safety, I slowed down to be sure I don't introduce ANY weakness into this structure. It'd likely only be used once (and I'd rather not have to use it a all), but I want it to work...and work well.
Cleco'd, ready for riveting
Flush Rivets going in
Finished, ready to mount into the airplane
