Brief Description: Installing platenuts for the fuel pump floor mount
With the doghouse built, now I positioned the floor covers, doghouse, heater box, and fuel valve covers so that I could match-drill holes for screws meant to hold the whole assembly in place...pretty slick design. Also drilled new holes through the floor angle pieces to hold the floor covers in place.
Disassembled it all and riveted platenuts all around.
Installed rubber channel onto the top flanges of the pump and filter cradles on the fuel pump bottom cover. These will protect the pump and filter.
