Brief Description: Building the fuel pump cover and floor mounts
Switched things up by spending time on the fuel pump assembly. I'll use a fuel-injected IO-360 engine, which requires a high-pressure fuel pump which mounts on the cockpit floor between Kelli's and my knees.
This design required me to modify the front floor center channel cover, shortening it and creating a pass-through hole (image 1). I then drilled/deburred/dimpled the doghouse pieces and prepped them for priming and riveting.
Trimmed the cockpit floor center channel cover (right)
Dimpling the fuel pump cover "doghouse"
Fuel pump cover doghouse assembled, ready for prime
