Sid & Houston Mayeux Project
Date:  3-22-2011
Manual Reference:  Landing Light
Brief Description:  Mounting screw plates for the landing light mount
The Duckworths kit came with a paper template we glued to cardboard and cut out. This template has two spots you punch out. The template fits forward inside the wing's leading edge up against the ribs, and the spots mark where we drill out these screw holes.
Once drilled, we riveted these screw plates in place. Later they will serve as mounts for the landing light bulb mount plate.
Screw plates in position
Houston match-drills the screw plates
Cleco'd to the ribs
Cleco'd to the ribs
