Sid & Houston Mayeux Project
Date:  3-20-2011
Manual Reference:  Landing Light
Brief Description:  Marked and cut the left wing's landing light hole
Started on the left wing's landing light, one of two Duckworth's 50-watt HID landing light systems I bought. I'll install this one as a landing light, and the other will go into the right wing as a taxi light.
This is the truly nerveous part...marking and cutting the leading edge hole. I did fine with the marking and cutting. However I'm at a logistics stop for a few days until I receive the right kind of grinding and finishing wheels to deburr and finish the edges. This leading-edge skin is pretty thick. I can't affort do dork this up.
Template taped in place
Hole is marked
Hole is marked
Hole is cut
Hole is cut
