Sid & Houston Mayeux Project
RV-7A
Stall Warner
Finishing the leading edge holes, priming
We used a dremel cutting wheel to cut across the two holes, creating the flapper arm's slot hole.
Forward slot hole is done
Rig rib mount holes are dimpled
System assembly plates primed
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
