The trim tab is next. First we riveted the trim tab spar's bottom side to the skin. You can see the rib I fabricated into the skin to the side of the trim tab cutout.
Next, lots of small adjustments as we test-fit the tab, clamped to both ends of the piano hinge, to get it lined up with the inboard edge and (most importantly) the elevator's trailing edge.
