Sid & Houston Mayeux Project
RV-7A
Elevator
Elev Trim servo mount
Mounting the elevator trim servo to the mounting plate took some trial and error, to be sure the assembly would fit through the VERY tight opening on the elevator's skin-mounted stiffener surface.
Mount plate marked, drilled, dimpled
Mounted, screwed on
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
