Sid & Houston Mayeux Project
RV-7A
Elevator
Sand and shape the stiffeners
Once Houston marked the cut lines, I snipped the excess metal, then sanded the cut lines down to a straight taper line with the belt sander. After that, I treated all the edges with the ScotchBrite wheel.
cutting the taper lines
Sanding the taper
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
