Brief Description: Elevator bearing bracket assembly, priming
The elevator center bearing bracket was fun. Required careful alignment of the left bracket side (which has the 6 rivet guide holes) with the bearing plate (also has the 6 holes) and the right bracket side (you guessed it...no holes). Clamp in place with a clamp cleco, and start drilling. Once done, I disassembled, deburred all holes, and primed the bearing plate. It'll dry overnight and I can assemble it tomorrow.
