Brief Description: Redux: Left Intake Snorkel mount, part 2
I finally got the air filter bracket from Van's Aircraft, allowing me to finish the top of the FAB snorkel's mount to the left intake ramp. With that done, I screwed/bolted both ends of the snorkel to their places on the fuel injection servo and the left intake ramp. I then repositioned the center FAB section that I had originally removed, and duct-taped it into place between the two outer sections. I used about 5 or 6 sheets of 9 oz. glass cloth and epoxy as a sort of 'tack weld' to join the three pieces. Tomorrow, once this 'tack weld' layup cures it all into one piece, I'll remove it and make the reunion more robust and permanent.
