Started the day off with replacing the short bolts holding on the rudder pedals and installed long bolts that go through both both flanges. Then I installed the spring and collar setup on the master cylinders. Afterwards all brake pedals return to neutral much easier. This shoudl solve any dragging brake issues.
Moved on to installing the braided brake lines from TS Flightlines. They look great. Now all I have to do is find a place to install the parkng brake and ziptie the lines in place.
