Finished up the wing fairings today. Started by cutting down the two vent line washers that was interfering. Got everything drilled, trimmed and dimpled. Moved on to the two vent lines between the fuselage and wing. Moved on to the main fuel lines between the selector valve and wing. I got the right one in but I'm not happy with it. The last 90 degree bend didn't turn out so well. I'll probalby pull it out and remake it.
