Peter's RV-7 Web Log
Date:  6-22-2003
Number of Hours:  8.00
Brief Description:  Assembly of HS
Spent most of the day assembling the HS spars. The call out for the rivets on the rear spar straps was questionable as to length. I used some longer rivets. I riveted the nose rib on the left HS, and then clecoed the skin and structure. I spent a little extra time to build a simple support for the HS... I assume that I can use it to store the stabilizer later on.
