Peter's RV-7 Web Log
Date:  6-15-2003
Number of Hours:  3.50
Brief Description:  Dimpled HS skin
Used a soldering gun to cut the protective layer of plastic away from the rivet lines. Dimpled the HS skin. We used the pneumatic squeezer for the outside holes and the C-frame for the interior holes. I held the skin apart and Eric wielded the hammer. At first we had problems with the deep holes, but by the end we had it under control. We finshed all the edges, cleaned the parts and are all prepped for the acid wash/Alodine/primer to come.
Striping the plastic off of the rivet lines
Eric using the pneumatic squeezer to dimple the skin
