Finally got around to starting the wings. It felt good to get back into it. Made the bushings for the aileron bellcranks and installed the bellcranks in the wings. The bushings seem to be a very tight fit in the bellcranks, but after some sanding and polishing, they seem to be moving freely. Greased the bellcrank bushings and torqued the bolts and attach fittings. Cut the push rods and primed the interiors of them.
