Installed the brake pedal assembly in the fuselage. I put two additional mounting holes in order to allow two positions further back; I am sure that I will never use them as my pedals will need to be all the way forward. I then disassembled the pedals to finish paint them. I'll let them dry overnight and then reinstall them on the tubes. I then tackled the tail bulkhead and the tial wheel spring. It was very difficult to dissaemble the rear bulkhead. Finally I drilled out some of thetop rivets to allow me to spread the sides and remove the bulkhead. Cut the lower fuselage for the tail wheel spring and drilled the forward mount. I needed to make a shim for the aft mount as it was slightly short. Clecoed it all back to gether and drilled the aft bulkhead rivets.
