Peter's RV-7 Web Log
RV-7
Attached Right Flap
Attached right flap. Made a split hinge pin; I will wire them off when the flaps are mounted for the last time. I also cut, drilled and tapped the flap actuator rods.
Split hinge pins with wire hole drilled
Flap acutator rods (x2)
RV-7 Home
409
154
Other
