Tims Web Site
Date: 2-4-2016
Number of Hours: 8.00
Brief Description: Canopy to bow rail fit and finish
Sanding, checking, sanding, checking, sanding, checking......and on and on and on... It was hard to know when I was getting to exact point at which to stop sanding. I worked my way down to where I could just see a hint of the blue fine line tape. Then slowly worked on down to try to find the edge without going to far. I finally pulled up and back a section of all the trim tape away from the finished edge and was very pleased. Need a little more work in the back and around the crossmember but very pleased, especially after being so SCARED.....
Still have a good bit more work to do but, its getting there... Next to re-tape, fill, prime, fill then paint.....Started drilling and countersinking the skirt for final fit and installation.
