Brief Description: moved right rudder cable fairlead
Physical examination indicated that the right rudder cable was rubbing against the control bar for the joysticks.
1) Removed the existing fairlead. 2) Cut new fairlead, forcing the right rudder cable approx 1/4" lower. 3). Cleaned and primed with zinc chromate primer. 4) Installed with 2 A4 rivets.
