Brief Description: Removed dual control provisions
The Zenith modificaiton requires changes to the center spar, which requires removing it from the aircraft. This in turn means the dual control provisions must be removed.
1. Removed bolts holding dual control provisions in place. 2. Removed dual control provisions. 3. Loosely installed bolts and nuts in provision, to facilitate reinstallation. 4. No markings on part, but none should be required, due to unique appearance.
