Jims Web Site
Date: 3-26-2011
Number of Hours: 2.50
Manual Reference: 6ZU3
Brief Description: Reinforce bellcrank
1. Removed esixting bellcrank support channel 6W6-10 by drilling out rivts with #20 bit. 2. Used 6W6-10 as template to establish area to be removed on new part 6ZU3-1. 3. Cut area to be removed on bandsaw, and filed edge. 4. Taped 6ZU3-1 in place, and backdrilled holes, using #20 bit, and clecoing as holes were added. 5. Cut lower and upper stiffners from "L" angle. 6. Established 40mm rivet pitch on angles. 7. Punched, and drilled with #40 drill. 8. Back drilled angles onto 6ZU3-1 with #40 bit, and clecoed. 9 Opened holes connecting angles to 6ZU3-1 with #20 bit, clecoing.. 10. Installed 6ZU3-1 with clecoes. 11. Taped lower stiffners, and backdrilled with #40 bit, clecoing as holes were added. 12. Opened holes with #30 bit. 13. Removed, deburred, and primed with zinc chromate. 14. Reinstalled, clecoing. 15. Riveted 6ZU3-1 in place. 16. Installed bellcrank supports and bellcrank.
Cleco in place
cleco in place
install bellcrank
