Brief Description: Added wiring from master relay to front of aircraf
1. Stripped end of #4 wire for lug. 2. Added lug. 3. Fastened to output of master relay, and capped with insulation. 4. Stripped #12 wire for lug 5. Fastened to coil lug of master relay, and capped with insulation. 6. Stripped end of #4 wire for lug 7. Added lug. 8. Fastened to ground lug on external power receptacle. 9. Added In-line fuse holder to positive batter terminal. 10. Spliced to #12 wire. 11. Labled wires leaving back of aircraft appropriately. 12. Drilled hole in center console back, and added grommet. 13. Routed wires through hole.
Note: there were several false starts, requiring significant routing and rerouting of wires.
