Brief Description: Cut rear top skin to mate with horizontal stabiliz
1. Installed templates previously made on aft fuselage. 2. Fine-tuned templates by cutting away interferring cardboard, and adding masking tape to bring templates to contour of horizontal stabilizer. 3. Removed templates, and clecoed to rear top skin. 4. Sprayed exposed area with zinc chromate primer, to determine area to be removed form skin. 5. Heat dried primer, to accelerate cure. 6. Cut out zinc chromated area on both faces. 7. Cleaned up edges with file and rotary sander. 8. Reinstalled rear top skin for fit check, and marked areas needing fine tuning.
