Jims Web Site
601XLB
6B2-3, 6B3-1,6B3-6
drilled upper tail section
1. Removed top rear panel 6B3-6, upper rear longerons 6B2-3, and "L" angles atop 6B3-6.
2. Deburred mounting holes.
3. Primed mating surfaces with zinc chromate primer.
4. Riveted splice between upper rear longeron 6B2-3 and upper forward longeron 6B11-1, using A5 rivets.
5. Positioned and clecoed 6B3-6, 6B3-1, and 6B2-3.
6. Clecoed to Side skin.
7. Riveted with A4 rivets.
8. Positioned and clecoed aft upper bulkhead 6B12-3.
9. Riveted with A4 rivets.
Aft longeron splice clecoed
Upper tail sedction parts clecoed
Selected upper tail section parts riveted
601XLB Home
2512
aircraft kit
controls
155
Elevator
elevator
352
155
542
horizonal stabilisze
Ignition
86
194
Landing gear
prop
Purchasing
53
155
rudder
Wiring
53
155
Zenith modification
86
194
