Brief Description: Installed closeout/brace at lower port end of pilo
1. Cut piece of "L" angle to correct length. 2. Removed gear upright and flap actuator doubler to allow better access. 3. Fit checked "L" angle, and marked existing rivet holes to establish pattern. 4. Established rivet lines, and marked rivet locations with fan at 25mm pitch. 5. Drilled pilot holes with #40 bit. 6. Removed metal on "L" angle that would interfere with gear upright or gear attachment rivets. 7. Back drilled holes into side skin and back skin using #40 and #20 bits, clecoing in place.
Cut piece of "L" angle with int4erfering metal removed
