Brief Description: Began installation of seat surface.
1) Cleaned out seat sling area in aircraft. 2) Placed seat assembly in aircraft, so it would assume the correct curvature. 3) Placed plastic around seat, to prevent overspray on surrounding surfaces. 4) Created 1" foldover along edge of vynl, glued, clamped, cured. 5) Sprayed top surface of seat, and corresponding area on vynl. 6) Mated surfaces, smoothed, and taped in place. 7) Repeated process for back of seat. 8) Repeated for bottom, up to cutout for stick. 9) Ran out of adhesive.
