1) Masked off console arm area, and secured foam to arm, using adhesive. 2) Cut upholstry for passenger side below console arm, using pattern previously prepared. 3) Secured upholstry to arm, using adhesive. 4) Cut upholstry for passenger side outer wall, using pattern previously prepared. 5) Secured upholstry to pattern, made of stiff cardboard, using adhesive. 6) Secured assembly to aircraft side, using Airtex cement.
