Brief Description: Fabricated and installed seat back clips
1. Cut stip of .040 aluminum for seat back clips, 24" long. 2. Marked off individual clips, and drill points. 3. Punched drill holes. 4. Pilot drilled holes with #40 bit. 5. Opened stress relief holes with #2 bit 6. Cut out marked portions on band saw. 7. Deburred. 8. Bent clip using brake and seaming tool. 9. Taped clips in place. 10. Back drilled with #40 bit and clecoed. 11. Opened holes with #20 bit, and clecoed. 12. Removed clips. 13. Deburred rivet holes. 14. Primed mating surface of clips and allowed to dry. 15. Clecoed clips back in place. 16. Riveted in place.
