1) Cleaned surface on port side with iso alcohol. 2) Peeled "EXPERIMENTAL" decal from backing. 3) Centered on surface, and worked out bubbles. 4) Cleaned location for N number on stbd side with iso alcohol. 5) Peeled backing from stencil, and positioned stencil on aircraft. 6) Peeled protective sheet from front of stencil. 7) Worked out bubbles. 8) Installed one row of masking tape around stencil. 9) Placed plastic sheets around masking tape, to prevent overspray. 10) Shot area with black spray. 11) Removed sheets, masking tape, and stencil. 12) Touched up area with black. 13) Repeated steps 4-12 for port side.
