Brief Description: Installed weather seal and experimental logo
1) Prepaed syringe to hold adhesive, and loaded syringe. 2) Removed 3 canopy hold-down screws and rivets on each side, to loosen canopy. 3) Using craft sticks, raised canopy- side close out from stbd side. 4) Filled weather strip with adhesive, and slipped over canopy and side closeout. 5) Worked weather strip onto canopy across front of aircraft. 6) Clamped ends of weather strip in place, where necessary. 7) Replaced rivets and tightened canopy hold-down screws. 8) Repeated process at canopy rear, but it was not necessary to remove rivets or losen canopy hold down screws. 9) Clamped and taped in place. 10) Replaced canopy side closeout rivets. 11) Installed "Experimental" sticker on passenger side.
