Brief Description: Primed under fuselage, painted sides white
1) Checked masks over existing red. 2) Mixed primer. 3) Loaded touch-up gun, and primed small areas under fuselage. 4) Cleaned touch-up gun. 5) Loaded primer gun, and primed remaider of area under fuselage. 6) Primed gear, and touched up stbd side. 7) Allowed to cure. 8) Rechecked masks over existing red. 9) Mixed white. 10) Two coats, fuselage sides, and upper gear surface.
