Brief Description: Mounted fresh air vents in panel
1. Clecoed stbd fresh air vent in panel with two clecoes. 2. Installed with 6-32 scrws, internal tooth washer, and an960-6 four places. 3. Snugged tight with nut driver. 4. Repeated for port side of aircraft.
Note: Scat or equivalent will be installed between back of vent and air inlet after some additional wiring.
