Jims Web Site
Date:  7-30-2014
Number of Hours:  3.50
Manual Reference:  6W10
Brief Description:  Set aileron deflection and cable tension
I removed the existging safties, and adjusted the aileron throw on each side for plus and minus 11 degrees. I also set the positioning so that both ailerons were roughly even with the wing flaps when they were in the neutral position.
Cable tensions were set at 40 pounds.
