Brief Description: Routed elevator trim servo cable
It seems odd that the formal drawings have no guidance on this subject, and that it is necessary to refer to the informal photo guide for limited information, but this seems to be the case.
1) With masking tape, temporarily routed cable between elevator and horizontal stabilizer. 2) Routed cable through area between horizonal stabilier and fuselage. 3) Drilled pilot hole in aft bulkhead with #40 drill, then opend to acommodate 3/8" grommet. 4) Deburred hole. 5) Installed grommet 6) Routed cable through grommet.
Note: Clamps must still be installed on the horizontal stabilizer to secure this cable.
