Jims Web Site
Date:  9-22-2014
Manual Reference:  (none)
Brief Description:  swapped oil pressure and temperature sensors
During the break in run, it became evident that the oil temperature and pressure readings were wrong. They simply did not match the engine behavior. About the same time, I stumbled onto some photos on the internet, showing the correct places to measure oil temperature and pressure on the Continental O200.
I had made a guess as to the locations, since the actual Continental documentation was silent in this area. Have I mentioned that the Continental documentation is severely lacking in most respects? That it is crummy, next to useless, and bad? I have now.
What I had done was to swap the correct locations for the two sensors. The pressure sensor would not fit in the spot where it should be installed, so I needed an entension hose. It took almost two weeks for this to be ordered, built, shipped, and received. Immediately following this, I got a cold, which wasted another week.
Finally, today, I got everything mounted, and did a test run. The gauge showed no oil pressure. It became evident the sensor lacked a ground: although the added cable provided a good ground, the fittings used did not. I added the ground, and things began to work.
We'll do a taxi run tomorrow. If all goes well, we're ready for cleanup and inspection.
Oil pressure sensor
Oil pressure sensor
Hose from engine to pressure sensor
Oil temperature sensor
