Jims Web Site
601XLB
(none)
Began cleaning engine parts
1. Placed parts in heated MEK bath, and cleaned ultrasonically.
2. Cleaned pistons as above, then grit plasted.
3. Soaked pistons in decarboning solution, then repeated grit blasted ring groves to remove carbon.
cleaning pistons
piston after some grit blasting
601XLB Home
2512
aircraft kit
controls
155
Elevator
elevator
352
155
542
horizonal stabilisze
Ignition
86
194
Landing gear
prop
Purchasing
53
155
rudder
Wiring
53
155
Zenith modification
86
194
