Jims Web Site
Date:  9-27-2010
Number of Hours:  2.30
Manual Reference:  (none)
Brief Description:  Secured brake lines
The brake line was previously routed along the front of the gear, and under the fuselage. There really isn't a good location for the line; just some that are less objectionable than others.
1. Located positions for adel clamps on port and stbd gear.
2. Marked holes for screw attach.
3. Drilled 5/8" deep with #40 bit.
4. Opened holes with #34 bit.
5. Tapped holes for 6-32 screws.
6. Installed dg4 adel clamps to brake line with ms series #6 1/2" screws.
7. Located adel clamps on port and stbd under fuselage.
8. Drilled with #30 bit, and clecoed.
9. Located adel clamps inside fuselage, drilled with #30 bit, and riveted with A4 rivets.
Note: Under fuselage and gear clamps will be removed for painting, then replaced and riveted or affixed with screws, as appropriate.
Stbd line attached to gear with DG4 adel clamps
Line fastened to fuselage with DG4 adel clamps
Interior line installation
