Jims Web Site
601XLB
(none)
Remove center spar
1. Drill out rivets holding center spar in fuselage.
2. Remove bolts holding center spar in fuselage.
3. Remove center spar from fuselage.
Spar and supports removed
fuselage area from which spar was removed
View of stbde area from which spar was removed
601XLB Home
2512
aircraft kit
controls
155
Elevator
elevator
352
155
542
horizonal stabilisze
Ignition
86
194
Landing gear
prop
Purchasing
53
155
rudder
Wiring
53
155
Zenith modification
86
194
