Brief Description: Added stiffner to stbd wing locker cover
I put an extra stiffner in the ceneter of the port wing locker, because I thought the panel would bow inwards otherwise. I didn't do this to the stbd locker, whikch was foolish, because it is now evident it's really needed. So, today I added the stiffner.
1. Measured and cut stiffner from "L" angle. 2. Drilled rivet holes to match side stiffners. 3. Crimped angle to match curve of wing. 4. Drilled #40 holes through wing cover and clecoed. 5. Opened holes with #30 bit & riveted to match other stiffners.
