Jims Web Site
Date:  10-13-2009
Number of Hours:  2.10
Manual Reference:  6B6, 6B10
Brief Description:  Lower engine mount
1. Locate lower engine mounts, p/n 6B6-5.
2. Cut shims to install under part, per dwg 6B10.
3. Pilot drill aft hole in 6B6-5 with #40 bit.
4. Tape parts in place.
5. Back drill aft hole with #40 bit, and cleco.
6. Check positioning.
7. Mark location of forward hole on lower front longeron, and center punch.
8. Pilot drill with #40 bit.
9. Check alignment.
10. Open hole for AN3 bolt with 3/16" bit.
11. Temporarily install AN3 bolt and tighten.
12. Remove aft cleco, and open hole for AN3 bolt with 3/16" bit.
13. Temporarily install AN3 bolt.
Mount taped in place
Hole drilled & bolted
Lower view
Lower view
