Jims Web Site
601XLB
6B13
Drill 5/16" bolt holes in wing uprights
1. Remove stbd aft wing upright.
2. Insert oiled center punch in lower outer stbd carry-through spar hole.
3. Center punch lower hole.
4. Move punch to upper outer stbd carry-through spar hole.
5. Center punch upper hole.
6. Rermove punc .
7. Remove fwd stbd wing upright.
8. Clean up center punch on aft upright.
9. Drill #40 pilot holes on press.
10. Open pilot holes to 5/16".
11. Replace fwd satbd wing upright.
12. Check clearances with AN5 bolt -OK!
13. Remove fwd stbd wing upright & replace aft stbd wing upright.
14. Repeat steps 2-12 for stbd aft upright.
15. Replace both uprights.
Note: an unsuccessful attempt was made to drill the 5/16" holes in the port wing uprights. The two uprights were scrapped, and more have been ordered.
Center punching the hole
#40 pilot holes
Upright installed
601XLB Home
2512
aircraft kit
controls
155
elevator
Elevator
352
155
542
horizonal stabilisze
Ignition
86
194
Landing gear
prop
Purchasing
53
155
rudder
Wiring
53
155
Zenith modification
86
194
