1. Added oil breather hose to engine. Hopefully, this will cut down on some of the oil being smeared all over everything. 2. There has been a potential problem with an exposed wire bundle under the port (pilot's side) instrument panel. It seems to me there is a danger of the wires snagging on the pilot's leg.
I fabricated a small closeout, fit checked in the aircraft, and drilled rivet/screw holes. I then deburred it, cleaned it, and primed it.
