During the movement of the aircraft to the airport, the pilot tube was damaged beyond repair. In retrospect, I should not have installed it until the plane was at the airport.
1. Removed existing tube by drilling out rivets. 2. Taped pilot and static line ids on plastic tubing. 3. Cut away old mounting base from tubes, turning it into a hole template. 4. Using the old mounting base, drilled mounting holes in new tube. 5. Saftyed pitot and static tubes to new assembly. 6. Clecoed assembly in place. 7. Riveted.
