Brief Description: swapped port and stbd obstruction light assemblies
When I connected the port strobe and tested it, I discovered I had swapped the assemblies for port and stbd.
1) Removed screws attaching port assembly to airframe. 2) Unsoldered hook splices connecting the port assembly. 3) Tagged assembly for stbd installation. 4) Removed screws attaching stbd assembly to airframe. 5) Unsoldered hook splices connecting assembly. 6) Moved stbd assembly to port. 7) Made new hook splices, soldered, and covered with heat shrink tubing. 8) Installed on port side with hardware. 9) Repleated on stbd side. 10) Spliced stbd cable at entry port to airframe. 11) Installed molex connectors to port and stbd strobes, and connected to power supply. 12) Installed ring lugs to port and stbd obsruction lights, and connected to TB1. 13) Verified strobes and lights come on when appropriate switch is activated.
