Brief Description: Worked on mating stbd wing to fuselage
1. Built spreader plug to open area for main wing spar. 2. Installed spreader plug. 3. Tried to install wing. 4. Built larger spreader plug. 5. Installled. 6. Tried to install wing. 7. Repeated steps 4-6. 8. Wing will slip in, but spreader plugs need to be removed before wing is all the way in. Hit brick wall on approach. Effort called due to heat, and the need for new ideas.
