Jims Web Site
Date:  6-25-2011
Number of Hours:  1.10
Manual Reference:  6B22
Brief Description:  Installed aileron fairleads at fuselage exits.
1) Marked cut and drill pattern on nylon fairlead material.
2) Punched hole locations
3) Drilled pilot holes with #40 bit.
4) Opened mounting holes with #20 bit.
5) Opened aileron cable holes with 1/2" bit.
6) Deburred holes.
7) Positioned first fairlead on stbd side, and punched locating hole.
8) Removed fairlead, and drilled holes with #40 bit.
9) Clecoed fairlead in place, and drilled remaining mounting holes with #40 bit.
10) Opened holes with #20 bit for A5 rivets.
11) Riveted fairlead in place with A5 rivets.
12) Repeated steps 2-11 for other stbd fairlead, and the two port fairleads.
Drilling pilot holes
Opening holes for A5 rivets
Riveting
Riveting
