Brief Description: Marked and installed airspeed indicator
1.Located airspeed indicator. 2.Researched FAA required markings. 3.Researched correct values on Zenith site. 4.Using marking tape, applied markings to indicator. 5.Installed indicator using #6 screws and indicator nuts. 6.Located closeout for radio from scrap. 7.Primed closeout and screw heads with zinc chromate primer. 8.Painted with white spray paint. 9.Allowed to cure, then installed in panel with #8 screws and locknuts.
