I mounted the Ammeter, voltmeter, oil temperature, oil pressure, and fuel pressure gauges in the instrument panel, using #6 machine screws, with internal tooth star locks and nuts. I also mounted the altimeter, using instrument clips and #6 screws.
The tach and ASI are on hand, but require a bit of work before they can be used.
